EAGLE User Support (English) Print problem labels are black rectangles
  • Subscribers 177 subscribers
  • Views 173 views
Hi, When I print my board, all the Lables off components will be print as a
black rectangle. When I turn the black option on,  in print options the
labels won't be visible any more on the printed A4.
Using HP4200 laserprinter.
    Most probably something is wrong with your printer driver or its
    cooperation with EAGLE. It also depends on your OS which you didn't mention.
    Make sure you use the latest printer driver, and also try setting the
    "always vector font" checkbox in the UI options.
    Finally, provided you use a current version of EAGLE (which you also
    didn't mention), you could try changing the printer rastering method by
    a setting in eaglerc.usr. However, you should first try the vector font.
    Tilmann
