EAGLE User Support (English) PCB prototyping, layout with holes in pads
  • Subscribers 179 subscribers
  • Views 332 views
Former Member over 17 years ago
I'm going to etch a few PCBs myself for prototyping, which means I'll also
have to drill all the holes. Years ago I used Ultiboard which would print
the layout with holes in the center of each pin/pad/via that needed
drilling. This really was helpful as it prevented the drill bit from
slipping.
How do I do this in Eagle? When I currently print a layout all the
pins/pads/vias are solid black and have no center hole.
Any suggestions would be appreciated,
Best regards
Sander Sassen
http://www.hardwareanalysis.com
  • esilviu
    esilviu over 17 years ago
    brd window / Options / Set / Misc .. Display mode = Real
    Cheers!
    "Sander Sassen - Hardware Analysis" <ssassen@hardwareanalysis.com> wrote in
    message news:fpkfea$3jd$1@cheetah.cadsoft.de...
    slipping.
    Best regards
    Sander Sassen
    Cheers!
    slipping.
    Best regards
    Sander Sassen
    ... and you can use drill-aid.ulp to narrow the center holes to a size
    that will really center the drill.
    Richard
