EAGLE User Support (English) Plated Through Hole Settings
  • Subscribers 177 subscribers
  • Views 211 views
Hi, just wondered where I specify that a hole is to be through plated within
eagle. Is there a specific via setting (like thermals, mask etc), does the
drill config file contain it, is there a specific package I need to use, or
is this Gerber CAM layer/flag. Can't find it in any of these?
Thanks for your help,
Paul Riding
    It's much simpler: a HOLE is not plated, while PADs and VIAs are (their
    holes are implicit in the layer "drills").
    If you, however, generate a single drill file from both layers (drills
    and holes), you will probably get all holes plated, unless you tell your
    board house anything else.
    Tilmann
    Thanks for that, all sorted.
    Paul Riding
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:fpmu57$2mk$1@cheetah.cadsoft.de...
    within
    the
    or
    Tilmann
