EAGLE User Support (English) TCRT 7000 library needed!!!
  • Subscribers 178 subscribers
  • Views 233 views
Hi, I'd like to ask if you have any VISHAY libraries, I need TCRT 7000
library.
I was trying to find something about that sensor and the problem is that
there isn't any datasheet of that sensor on the web. I have to use that
sensor in my project and there isn't any Eagle Library too image, All I
found on the web is only the picture of pins(I include the picture).
Could you help me with preapearing the library? I have never been doing
any library that is so complicated.
regards Krzysiek Sielewicz
    library.
    Sure you have the part number and/or manufacturer correct ?
    There is no such part number on the Vishay site.
    If it is indeed a Vishay part, it may be a manufacturer's special, in
    which case a direct question to the technical department of Vishay may help.
    John G.
