EAGLE User Support (English) How to save files to be readable on older versions
  • Subscribers 187 subscribers
  • Views 2070 views
organstan
organstan over 7 years ago
I'm currently using version 9.1.3 but will upgrade to the latest version when I have some spare time. I have a colleague who uses version 8.0.1 but he cannot open my files.  Can I save my files in an older format?
  • organstan
    0 organstan over 7 years ago in reply to geralds
    Hi Gerald, that's great.  Thank you.
    I need to update to 9.3.2, I just worry something will go wrong during the process.  I guess I'll do it during the holiday weekend !
    Stan
  • geralds
    0 geralds over 7 years ago
    You can save your sch or pcb or the library as a copy down to 7.xx compatibility.
    Go to the menu "File", then "Save copy for EAGLE 7.xx"
    Each 7.xx versions are readable with that newer Eagle versions, e.g. 8.xxx.
    Tip:
    I would suggest to make an update from your version to the actual version 9.3.2
    Gerald
