EAGLE User Support (English) Move smashed element name from a script.
  • Subscribers 178 subscribers
  • Views 195 views
I'm working on a set of ULPs/Scripts that will duplicate the layout of
components when you copy sections in a schematic. The last step in my
ULPs/Scripts is to have it match the layout of text in smashed elements.
Does anyone know if there is a way to move a smashed element name from a
script/ulp? The main thing I don't understand is how to address the name of
the element using the MOVE, ROTATE etc commands. The only way I have found
to select the name of the element from a script is to mimic a mouse click at
the coordinates of the name. This isn't ideal for an automated script. I
would rather be able to select it using the element name i.e. "MOVE C1 name"
or something.
Brian
  • Richard_H
    Richard_H over 17 years ago
    or something.
    Brian
    There is no other way to select texts. You have to use its coordinates.
    Richard Hammerl
