EAGLE User Support (English) Polygon Fill Disappearing
  • Subscribers 177 subscribers
  • Views 812 views
Is there any way to ensure that the filled area inside a polygon remains
filled once you save and close a file and then reopen it.
I have a ground plane that disappears once you open the file and the
Ratsnest button needs to be used again to fill the polygon. The polygon is
always in the correct position just the filled area has disappeared.
Any ideas?
Andrew
    Any ideas?
    Andrew
    That is normal. Only outline of a polygon is the only part saved not the
    fill which could would make the saved file very large. It has to be
    regenerated when you open a file or do a run a cam process.
    Paul R.
    Thanks Paul,
    At least i know im not doing anything wrong.
    Andrew
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:fq7kik$7v9$1@cheetah.cadsoft.de...
    is always in the correct position just the filled area has disappeared.
    Any ideas?
    Andrew
    Paul R.
