EAGLE User Support (English) resistor pad size
  • Subscribers 177 subscribers
  • Views 327 views
resistor pad size
hi!
how can i easily chanhe pad size for all resistors on pcb, but if there is
wire on pad's way, pad will make isolated part (something like polygon)...
i use eagle 4.13, freeware edition (limited to 2 layers and 10*8cm pcb)...
TIA
I am Locutus of Borg,
Your life as it has been is over,
From this time forward,
You will service... US!
    You'll find it un the drc and it's called "resting", you haev to increase
    the percentage.  As long as your drc has clearances set up, it will provide
    the right clearance or tell you if it's wrong.
    Hope that helps.
    "Locutus of Borg" <igor.bedek+njuz@GoogleMAIL.com.spam.is.in.the.air> wrote
    in message news:1iibsp8cwwoaj$.1qf0lwioq8gm0.dlg@40tude.net...
    hi!
    TIA
    Dana 03.03.2008. 19:44, Bryan Mills lupi chelom po tipkovnici i nastade
    slijedeci tekst:
    Hope that helps.
    thanks!
    that solved about 3/4 of my problem...
    i saw on some "kemo" kit boards, if wire is going near pad, pad is
    automatically making "isolation", so there won't be short circuit...
    something like isolate option when drawing polygons; pad isn't totaly
    rounded, on place where wire is comming, it is cut (when i find some
    picture, in the morning, i will post it)...
    Do you mean shaved pads? As far as I know, only the smARTWORK from
    Wintek is using them.
    Best Regards
       Asko
