EAGLE User Support (English) GC-Prevue and EagleCAD
  • Subscribers 177 subscribers
  • Views 506 views
When I generate RS274X and Excellon files for my project I import into
GC-Preview to double check the gerbers.  I get a weird error about "WARNING:
Zeror and/or negative dimension tools detected in the floowing tool tables:"
and 2 of the gerber files are listed (my .pls and .plc files).
I can open the aperture list and I see a 0.0 dimension 1 value for one of
the entries.  Any idea why, or how to track this down and fix it?  I
shouldn't be having zero dimension apertures generated, should I?
Doug
    "Doug Miller" <user@default.dom> wrote in message
    news:fqk2bc$vq9$1@cheetah.cadsoft.de...
    "WARNING: Zeror and/or negative dimension tools detected in the floowing
    tool tables:" and 2 of the gerber files are listed (my .pls and .plc
    files).
    Doug
    With a little more playing around, it appears that it is holes that are
    putting a 0.0000 dimension object on the silkscreen layers.  I understand
    they are used to place restrictions on the autorouter.  Is there a way to
    disable this though, say, if you don't ever use the autorouter?  Or possibly
    have the GERBER_RS274X device not output dimensions with aperature size of
    zero?
    Thanks!
    Doug
    files).
    zero?
    Due to these implicit objects in the dimension layer, I always recommend
    to not use this layer for generating the outline data of the board.
    Simply draw a narrow line (0.01mm for example) in the milling layer, and
    use this layer to generate the outline data for the board house. The
    line should be very narrow to avoid discussions which of the three
    possible interpretations (inner, center, outer) is valid. image
    I use the dimension layer only for documentation (i.e. the board outline
    is drawn with a somethat wider line, so it appears nice on printouts). I
    have requested several times to either remove these implicit objects
    from the dimension layer, or make its width adjustable, but this has not
    been fixed for many years now.
    Tilmann
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:fqlgqe$1ej$1@cheetah.cadsoft.de...
    files).
    of
    possibly
    of
    zero?
    Tilmann
    Tilmann,
    That's a great suggestion.  I think I will follow your practice and utilize
    the milling layer for the actual board outline.
    Thanks a million,
    Doug
    Tilmann
    Being precise: nobody remembers except you. No offense. See "Newsgroup
    limitations" in eagle.suggest.eng. I have thought about this every so often,
    but your statement here and another one elsewhere gave me reason to write a
    bit more about it... though I am sure nobody remembers it in a week. For the
    same reason.
    T.
    Tilmann,
    utilize the milling layer for the actual board outline.
    Thanks a million,
    Doug
