EAGLE User Support (English) I have four layer board with layer two as a ground plan and the rest signals.
  • Subscribers 178 subscribers
  • Views 216 views
Former Member over 17 years ago
The PCB board shop tells me I have overlapped thermal and antipads on my
ground plane.  There is one place on my PCB that I see this.  It's on a
through hole part where the pins are very close together.  I used the
autorouter and I get no DRC errors, however one of the thermal fins is
missing on this part due to an adjacent antipad.  What is the best way to
fix this?  Is there a setting in the DRC tool that can allow the autorouter
to fix this automagically?  I'm using the Eagle default settings now.
Thanks in advance.
    See the recent discussion about why using supply layers is so error prone:
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Thanks in advance.
    For inner layers, you don't need thermal pads.  Thermals are only needed
         on outside layers (TOP/1, BOT/16) for soldering through hole parts.
    BTW, I run GCPrevue to check my boards before sending them to be
    fabricated.  Some times I have freeDFM.com check my board as well.
    FreeDFM is free and fast (only a few minutes).
    HTH
    -Dave Pollum
