EAGLE User Support (English) MAC alt key mappings in x11?
  • Subscribers 179 subscribers
  • Views 464 views
Hi Everyone,
   I tried searching, but can't seem to find anyone else with this
problem...  I recently purchased a mac running leopard.  The alt key
doesn't map properly to eagle.  I can't seem to use any short cuts that
require it (really annoying).  I opened /EAGLE-X11/bin/Xmodmap and found:
!! Definitions necessary to have the Alt key passed
!! correctly to X11 applications on Mac OS X:
clear Mod1
keycode 66 = Alt_L
keycode 69 = Alt_R
add Mod1 = Alt_L
add Mod1 = Alt_R
Is this correct for the newest version of OSX?  Are there any other
settings I need to change in order to utilize the alt key?  Thanks,
David
  • Richard_H
    Richard_H over 17 years ago
    David Gal schrieb:
    Hi Everyone,
    clear Mod1
    keycode 66 = Alt_L
    keycode 69 = Alt_R
    add Mod1 = Alt_L
    add Mod1 = Alt_R
    David
    Here a part of the installation guide:
    In order to allow the Alt key to be passed to EAGLE (as well as
    other X11 applications) you need to enter
    cat /Applications/EAGLE-X11/bin/Xmodmap >> $HOME/.Xmodmap
    in the "Terminal" window.
    Disable the options
      Input/Follow system keyboard layout
      Input/Emulate three button mouse
    of the X-Server's preferences.
    Therefore you have to click on the X11 icon in the "Dock".
    Goto the X11 menu bar on top of your screen and do a right mouse
    click on the X11 menu. Select Preferences and disable the options
    mentioned above.
    If you don't see the "Dock" while X11 is running it started in
    full screen mode automatically. Please use a "command - option - A"
    keystroke to leave this mode.
    Close the "Terminal" window now.
    Does this help?
    Richard Hammerl
    Richard Hammerl wrote:
    David Gal schrieb:
    Hi Everyone,
    clear Mod1
    keycode 66 = Alt_L
    keycode 69 = Alt_R
    add Mod1 = Alt_L
    add Mod1 = Alt_R
    David
    Disable the options
    mentioned above.
    Does this help?
    Hi Richard,
       Yes this helps.  Thanks.  Is there an easy way to avoid having to
    type the cat /Applications/EAGLE-X11/bin/Xmodmap >> $HOME/.Xmodmap every
    time I want to open eagle?  In order for me to get proper keymappings I
    need to do this every time...  Thanks,
    David
    David Gal schrieb:
    Hi Everyone,
    clear Mod1
    keycode 66 = Alt_L
    keycode 69 = Alt_R
    add Mod1 = Alt_L
    add Mod1 = Alt_R
    David
    Disable the options
    mentioned above.
    Does this help?
    Hi Richard,
    David
  • Richard_H
    David Gal schrieb:
    Hi Everyone,
    found:
    clear Mod1
    keycode 66 = Alt_L
    keycode 69 = Alt_R
    add Mod1 = Alt_L
    add Mod1 = Alt_R
    David
    Disable the options
    mentioned above.
    Does this help?
    Hi Richard,
      Yes this helps.  Thanks.  Is there an easy way to avoid having to type
    the cat /Applications/EAGLE-X11/bin/Xmodmap >> $HOME/.Xmodmap every time
    I want to open eagle?  In order for me to get proper keymappings I need
    David
    Normally it should be enough to do it once.
    Doesn'T exist  a file named .Xmodmap in your home directory?
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    David Gal schrieb:
    Hi Everyone,
    found:
    clear Mod1
    keycode 66 = Alt_L
    keycode 69 = Alt_R
    add Mod1 = Alt_L
    add Mod1 = Alt_R
    David
    Disable the options
    mentioned above.
    Does this help?
    Hi Richard,
    David
    It seems as if Leopard doesn't automatically read the .Xmodmap.
    This must be done from your user .xinitrc
    So you can do this to get a default .xinitrc that will load the .Xmodmap
    file:
    cat /usr/X11/lib/X11/xinit/xinitrc >> ~/.xinitrc
    (the cat and the >> will append the contents of the sample xinitrc file
    to whatever you have there, if anything; if you had other stuff in there
    you'll have to edit the file).
    If you already have a .xinitrc file you can add the lines:
    if [ -f "$HOME/.Xmodmap" ]; then
       xmodmap "$HOME/.Xmodmap"
    fi
    to get the X server to use your .Xmodmap file.
  • tehn@monome.org
    tehn@monome.org over 17 years ago in reply to autodeskguest
    file:
    fi
    thanks for the hints, but i'm having the same problem.
    os x 10.5.2 fresh install on a macbook.
    it seems that X11 is mapped properly:
    salt:~ tehn$ xmodmap
    xmodmap:  up to 2 keys per modifier, (keycodes in parentheses):
    shift       Shift_L (0x40),  Shift_R (0x44)
    lock        Caps_Lock (0x41)
    control     Control_L (0x43),  Control_R (0x46)
    mod1        Alt_L (0x42),  Alt_R (0x45)
    mod2        Meta_L (0x3f),  Meta_R (0x47)
    mod3
    mod4
    mod5
    still no alt love in eagle. any ideas?
    much appreciated.
    brian
