EAGLE User Support (English) What does "Polygons may have fallen apart" mean.
  • Subscribers 187 subscribers
  • Views 238 views
e14 Contributor over 18 years ago
Everything I've tried so far gets this error in the autorouter.  I'm
creating a polygon named gnd.
The board routes fine without the polygon.
    AFAIK, this means that portions of your ground polygon aren't connected
    to anything.  These are also known as "orphaned" polygons.  If you have
    ground polygons on the other side of the PCB, then use vias to connect
    the top and bottom ground polygons.  If ground "orphans" can't be
    connected to ground, then those "orphaned" should be deleted (turned
    off).  See CHANGE -> ORPHANS -> ON / OFF.
    HTH
    -Dave Pollum
