EAGLE User Support (English) ATX motherboard connector footprints
  • Replies 8 replies
  • Subscribers 178 subscribers
  • Views 2041 views
Does anybody know where I can get Eagle footprints for ATX motherboard
power connectors and ide power connectors?
thanks
    You have some options:
    1.  Look in the libraries that came with EAGLE.
    2.  Look on the cadsoft.de website for libraries that contain these parts.
    3.  Look on the manufacturer's website.  Molex is one manufacturer that I
    know makes or made these connectors.  If they don't offer an EAGLE library,
    you can download the datasheet or drawings and use the measurements to draw
    your own library of parts up.
    <user@domain.invalid> wrote in message
    news:fqrvno$cpb$1@cheetah.cadsoft.de...
    thanks
    On Fri, 7 Mar 2008 somebody anonymously wrote saying :
    thanks
    I'm fairly sure the main ATX power connector is in one of the libraries,
    possibly con-amp or con-molex. I have a feeling it's a "mini-fit".
    Don't know about the HD power connectors.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    thanks
    Thanks for the reply Dan,
    I looked in the Eagle Libraries to no avail, and I checked the website
    with no luck. I simply cannot believe that a universally common part
    such as the atx power connector that probably resides on every
    motherboard that is sold in the US as well as Europe is not included in
    the libraries. They  include the USB connectors  and the serial ports
    etc.???
    thanks
    Thanks for the reply, its not in there
    I'm puzzled, i cant believe this common connector hasnt already been
    designed.
    designed.
    The ATX power connector is a molex, and I'm fairly sure it's a mini-fit.
    If so then download con-molex-minifit from the cadsoft website.
    believe a word.      |
    designed.
    Thanks Rob, it was in the con-molex-2 lbr, now I have to find the 4 pin
    connector that is used for the hard drives and cdrom drives. is that
    also a mini-fit?
    thanks for your help
    designed.
    mini-fit. If so then download con-molex-minifit from the cadsoft
    website.
    pin connector that is used for the hard drives and cdrom drives. is
    that also a mini-fit?
    Are they PCB mounted connectors ?  I would have thought not.
    Best Regards:
                         Baron.
    Ah, yes, I forgot it had been renamed after I uploaded it.
    now I have to find the 4 pin connector that is used for the hard
    drives and cdrom drives. is that also a mini-fit?
    No. The mini-fit range are 4mm spacing, the hard drive power connector
    is 5mm (actually it's 0.2"). Try FLOP-4W from con-amp.lbr (it's for a
    5.25" floppy rather than a 3.5" so it's the same as the CD / HDD one).
    believe a word.      |
