EAGLE User Support (English) pcb and diagram consistent
  • Subscribers 179 subscribers
  • Views 719 views
Is there a way to correct the component (type/shape) on de pcb layout
when I have changed the circuit diagram? And visa versa (back annotate)
when I changed the shape on the PCB and want to correct the circuit
diagram? So I get a pcb and diagram consistent to each other.
Thanks...
Wijnand Nijs
    <user@domain.invalid> wrote in message
    news:fqtsci$ruu$1@cheetah.cadsoft.de...
    Is there a way to correct the component (type/shape) on de pcb layout when
    I have changed the circuit diagram? And visa versa (back annotate) when I
    changed the shape on the PCB and want to correct the circuit diagram? So I
    Thanks...
    Wijnand Nijs
    Always keep both the schematic and board file open.  That way annotation
    will happen automatically.
    Bert Menkveld
    Dana 08.03.2008. 12:13, user@domain.invalid lupi chelom po tipkovnici i
    nastade slijedeci tekst:
    when you are changing something, schematic and board must be opened at the
    same time... if they are, and if you change something in sch, it will be
    changed on board...
    HTH
    I am Locutus of Borg,
    Your life as it has been is over,
    From this time forward,
    You will service... US!
    autodeskguest over 17 years ago in reply to autodeskguest
    changed on board...
    HTH
    How simple...
    Thanks a lot, greetings...
    Wijnand
    Dana 11.03.2008. 21:02, user@domain.invalid lupi chelom po tipkovnici i
    How simple...
    NP
    regards!
    On Mon, 10 Mar 2008 20:42:43 +0100, Locutus of Borg
    changed on board...
    So, if one screwed up and made a change on the schematic without the
    board being opened are they inconsistent forever or can it be fixed?
    TIA
    John - who just did that yesterday and should have stopped when he got
    the warning message, but didn't.
    Former Member over 17 years ago
    Yes, fix all errors reported after running ERC (make a hardcopy, it's
    easier). Maybe you must run the ERC a couple of times.
    r
