EAGLE User Support (English) How do I get rid of the IC pin names in a schematic?
  • Subscribers 179 subscribers
  • Views 339 views
My circuit uses a hex inverter IC that I designed myself to get the
Vcc and Vss pins where I wanted them on the schematic.  The symbol
shows "P$1"  and "P$2" in each element and darned if I can figure out
how to get rid of them on the schematic.
I went back to the device design but could not do it there nor at the
symbol design.
TIA
    symbol design.
    TIA
    When putting the pins in the symbol, choose the pin type without
    name/number. (In the toolbar along the top of the editor window in my
    version)
    John G.
  • Richard_H
    Richard_H over 17 years ago
    symbol design.
    TIA
    You have to change it in the Symbol Editor an use CHANGE VISIBLE for
    the pins.
    Richard Hammerl
