EAGLE User Support (English) Routing SMD device with 0.5mm pitch
  • Views 512 views
KennyMillar
KennyMillar over 18 years ago
Hello everyone,
I'm having trouble routing signals to an SMD device which has 0.5mm pitch
connections which are just 0.35mm apart.
It's a 16 way FPC (Flexible ribbon cable) connector. (Similar to Molex
52746)
I have attached a sample board and schematic (SMD_CON.sch), and the library
with my part in it.
I have created a CLASS with wire thickness of just 0.35mm and clearance of
just 0.15mm. In the auto router I set the routing grid to just 0.1mm, but
still it will not route the signals.
I guess I am just not using the correct approach.
Can anyone help me?
In case the attachment is not allowed, it is also available here:
http://www.kennymillar.co.uk/SMD_CON.zip
Thanks in advance.
-Kenny M.
SMD_CON.zip
    Kenny wrote:
    Hello everyone,
    52746)
    with my part in it.
    Can anyone help me?
    Thanks in advance.
    -Kenny M.
    Kenny;
    Your connector has 0.35mm wide smd pads that are on a 0.50mm pitch (pad
    center to center).  The best way to route this is to start from the SMD
    pads to the through hole connector pads, using 0.3mm traces.  DRC will
    complain a lot simply because the SMD pads are too close, if you use the
    default settings.
    I've include a zip file (SMD_CON_1.ZIP) to show how I manually routed
    the traces.
    HTH
    -Dave Pollum
    smd_con_1.zip
  • KennyMillar
    Excellent suggestion.
    Many thanks.
    -Kenny
    "Grzegorz Zalot" <complex@alpha.pl> wrote in message
    news:fr8jjv$jvd$1@cheetah.cadsoft.de...
    Hello Kenny !:
    Hello everyone,
    52746)
    library with my part in it.
    of just 0.15mm. In the auto router I set the routing grid to just 0.1mm,
    but still it will not route the signals.
    Can anyone help me?
    Best way is to roule manually all track from the connector away ....
    Maybe then you can start the autorouter but the ends of the manually
    routed wires should have more distance than 0,5 mm - and of course on
    grid.
    HTH
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
    Hello Kenny !:
    Hello everyone,
    52746)
    with my part in it.
    Can anyone help me?
    routed wires should have more distance than 0,5 mm - and of course on grid.
    HTH
    Grzegorz Zalot
    complex ltd.
