EAGLE User Support (English) replace library names in schematic
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 2682 views
gharryh1957
gharryh1957 over 7 years ago
Using exp-project-lbr.ulp will create alibrary from my project. But it doesnt replace the part directive in the schematic to the newly created libray.
Is there a way to do that??
Greetings
Harry
  • rachaelp
    0 rachaelp over 7 years ago in reply to WarrenBrayshaw
    WarrenBrayshaw  wrote:
    Go here
    http://eagle.autodesk.com/eagle/ulp
    and search for
    exp-lbrs-replace2.ulp
    This does what you want.
    If you are using any of the more recent versions of EAGLE since mid v8 then the built in exp-lbrs.ulp which ships with EAGLE and accessible from File->Export->Libraries incorporates all this functionality and also fixes some incompatibilities caused by the addition of managed libraries. You should use that instead.
    Best Regards,
    Rachael
  • WarrenBrayshaw
    0 WarrenBrayshaw over 7 years ago in reply to gharryh1957
    Go here
    and search for
    In Bob Starr's words
    "I modified the export project ULP to allow exporting all parts into a single project specific library. BUT, the magic part is that it also generates a script you can run afterward to replace all parts in the schematic so they reference the newly created project specific library. I\'ve also updated the ULP so it now shows a list of all libraries used in a schematic and it allows selecting which library parts to export/replace. Now you can easily export and edit any of the parts in any of your designs within a single project specific library on the fly!"
    HTH
    Warren
    0 autodeskguest over 7 years ago in reply to autodeskguest
    Go here
    and search for
    HTH
    Warren
    On 17/09/2019 5:42 PM, Lorenz wrote:
    Harry Herbert wrote:
    But if my project contains parts from 10 different libraries, must I then execute this command ten times??
    yes
    it could be automated using an ULP though.
    there might even be one around already.
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    This email has been checked for viruses by Avast antivirus software.
    https://www.avast.com/antivirus
    0 autodeskguest over 7 years ago in reply to gharryh1957
    yes
    Lorenz
  • gharryh1957
    0 gharryh1957 over 7 years ago in reply to autodeskguest
    created libray.
    see "help update"
         UPDATE old_library_name = new_library_name;
    Lorenz
  • rachaelp
    Hi Harry,
    You haven't said what version of EAGLE you are using but in the more recent Autodesk versions, the exp-lbrs.ulp ULP which is called from File->Export...->Libraries gives an option to create a replace script. Once run the libraries in the board will be pointing a the exported libraries instead.
    Best Regards,
    Rachael
