EAGLE User Support (English) TO-252AA package?
  • Subscribers 178 subscribers
  • Views 844 views
TO-252AA package?
I am stuck again on another part because i could not figure out how to
search the libraries for different packages to copy and make a new part.
When i make a new part i go to, project and select new library, then i
select package, usually i can find a package, but this is just looking
though the control panel list. This is the point where i need to upload a
package, or search for one but cant seem to figure it out. Any help on this
would be much appreciated.
The part i am looking for is TO-252AA i have read some place that they
renamed these diodes to something else. Not too sure on this though...
spikes
    Former Member over 17 years ago
    Found TO252 in following libs: transisor (from CadSoft), infineon,
    infineon_tle_power, ipc-rcl, ipc-smd, linear4, micro-siemens, ref-packages
    (most variants), siemens.
    most of them are from the download-area.
    r
    Hello Ing. J.M. Rafetseder !:
    Most of them containing some mistakes image !!
    Did you try to solder this package with full surface covered by solder
    paste ?????
    regards
    Grzegorz Zalot
    complex ltd.
    office tel/fax : +48 32 2505840
    mobil : +48 501 301515
    http://www.complex.org.pl/
    paste ?????
    I think if we find errors in the libraries in the download area we shall
    tell that to cadsoft to remove or fix them.
    Marco / iw2nzm
