EAGLE User Support (English) Smashed but can't move
  • Subscribers 177 subscribers
  • Views 399 views
I'm having trouble moving some text that is associated with a particular
library part that someone else created for me.  In fact, I cannot even
select these certain text items by grouping or selecting.  I have smashed
the part and I have been able to select and move other text items associated
with the part.  I am stumped and this is the last thing I have to do before
completing my design.
Chris I.
    It depends on the way to package is designed in the library.
    Only "placeholder" text (like >NAME, >VALUE etc.) is movable after
    SMASH. If your package contains additional text that is simply dropped
    in somewhere, it's not movable.
    Tilmann
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:frnq68$5mb$1@cheetah.cadsoft.de...
    associated
    before
    Tilmann
    Hmm.  Well then, is it possible to delete this text or do I need to re-do
    the library part?  I can't seem to group or select it.
    Chris I.
    You can't partially remove a package while editing the board.
    If you want to remove some detail, you need to edit the package in the
    library, then UPDATE your design.
    Another good reason to not put too much unnecessary details into package
    definitions.
    Tilmann
    news:frotgb$hec$1@cheetah.cadsoft.de...
    definitions.
    Tilmann
    Thanks.  That worked.
