EAGLE User Support (English) how to create  VIA with Diameter = 0.01" ?
  • Subscribers 177 subscribers
  • Views 154 views
I am trying to create a small via ( Diameter = 0.01", Drill=0.005").
When I do that Eagle changes diatemer to 0.021" automatically.
When I click Info on via I can ee  Diameter = 0.021/0.021" ( 0.01).
How can I solve that ?
    Vitaliy
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
    On Wed, 19 Mar 2008 21:12:16 +0200, MiniMax <mini_max@pochta.ru> wrote:
        Vitaliy
    After all I found  out one doc that describes how to solve the problem
    http://www.lumatron.ch/download/Eagle_FAQ.pdf
    Q. How do I define the PAD and VIA diameter?
    A. Pad and Via diameter are controlled by the DRC/RESTRING parameter.
    The diameter will be calculated according to the Restring % factor that has
    been setup.  The formula works the following way:
    DIAMETER = DrillSize + 2DrillSize(% Restring)
    You are restricted by a MIN and MAX values.  These values may be changed if
    needed.
        Vitaliy
    needed.
