EAGLE User Support (English) How to make a connection to a polygon
  • Subscribers 178 subscribers
  • Views 229 views
I've created a polygon on the solder side of my 2-sided board.  How do I
connect to it from the component side?  My board is completely routed, so I
can't use a net.  Do I just punch through with a via?  Thanks.
Karl
  • esilviu
    esilviu over 17 years ago
    rename-it to your gnd signal
    "Karl Lautman" <karl@lautman.com> wrote in message
    news:fs70vo$slg$1@cheetah.cadsoft.de...
    I can't use a net.  Do I just punch through with a via?  Thanks.
    Karl
    do I connect to it from the component side?  My board is completely
    routed, so I can't use a net.  Do I just punch through with a via?
    Thanks. Karl
    Yes, you use vias.  But first, as suggested, you should probably name your
    polygon something (often GND).  Then you can attach to it with a named via:
    via 'gnd'
    Bert Menkveld
