EAGLE User Support (English) Converting to DWG format
  • Subscribers 183 subscribers
  • Views 2607 views
I'm trying to convert .BRD file to .DWG format for Autocad. Anyone know how
to do this or if it's possible? Any help would be appriciated.
Thanks in advance
    Thanks in advance
    Use DXF.ULP to export the drawing as a DXF file.
    If you want to have editable text in the Autocad file, in Eagle
    options->user interface menu uncheck the 'always vector font' and
    'Persistent in this drawing' blocks. Also, in DXF.ULP, uncheck 'Always
    vector font'. This will let Autocad import actual text strings instead
    of vectors. Then, in Autocad, type DXFIN in the command line. Depending
    on the release of Autocad you have, it might have to be a new, blank
    drawing for the command to work.
    HTH
    Jack
