I make a ground plate using a polygon with thermals on.On all pads
thermals are applied correctly using + pattern. Vias are entirely
connected as if thermals was turned off. Any ideas to apply thermals on
vias ?
vias ?
Hello Dionysios Skamnakis !:
vias ?
Did you checked the "generate thermal for vias" option in DRC menue -
supply section ?
Grzegorz Zalot
complex ltd.
office tel/fax : +48 32 2505840
mobil : +48 501 301515
on vias ?
supply section ?
That was the problem!
thanks
