EAGLE User Support (English) I have an HP laptop in which I've installed eagle 5.11 I have a professional license for it I tried to install the license it doesn't recognize
  • Replies 17 replies
  • Subscribers 189 subscribers
  • Views 2873 views
tjnomad
tjnomad over 6 years ago
CadSoft License Registration File
Copyright (c) 2012 CadSoft
< credentials removed>
    0 autodeskguest over 6 years ago in reply to tjnomad
    Am 18.01.2020 um 00:26 schrieb tj Schmidt:
    That makes sense now thank you for you're time.
    https://www.element14.com/community/message/287314
    Cadsoft server is still running.
    In my cadsoft delivery note (with a number)
    contains a direct link
    http://www.cadsoft.de/cgi-bin/..........
    to the license but that leads to AD which I did not check further.
    It also contains precise instructions how to obtain the activation key.
    The
    http://web.cadsoft.de/license.htm
    link shows cadsoft.
    I entered the requested numbers. The answer was no code for serial nuber
    xxxxx.
    No wonder since my 4 weeks are also loooong ago.
    So, if you contact AD the number of your delivery note may also be
    important.
    Joern Paschedag
  • tjnomad
    0 tjnomad over 6 years ago in reply to autodeskguest
    0 autodeskguest over 6 years ago in reply to autodeskguest
    Am 17.01.2020 um 06:45 schrieb warrenbrayshaw:
    On 17/01/2020 5:32 am, tj Schmidt wrote:
    Nothing is working.  It should upper lower case dosn,t matter this
    should work.  I found the original license key file same error!
    https://www.element14.com/community/message/287233
    This youtube video may give you some assistance
    https://www.youtube.com/watch?v=MBsn0sn907M
    Version 5 may not quite work this way but there maybe something within
    the video that guides you to success
    HTH
    Warren
    The license file alone is not the problem. This file allows you to get
    the installation code from cadsoft server.
    And for security reasons this code on the server was available for 4
    weeks only.
    So, the request time is long over, and cadsoft doesn't exist any more.
    You can only contact AD and hope that they still run the license server
    and that they are willing to help.
    (Chance is low but newsreader is still running)
    Joern Paschedag
    Nothing is working.  It should upper lower case dosn,t matter this should work.  I found the original license key file same error!
    HTH
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    As an aside, your license entitles you to all versions of v5.
    You may as well attain the advantages of the last v5 version which is
    5.12 and you can get it here
      ftp://ftp.cadsoft.de/eagle/program/5.12/
    Regards
    Warren
    Thunderbird!
  • tjnomad
    upper lowercase doesn't matter same error
  • tjnomad
    On 12/01/2020 2:14 am, tj Schmidt wrote:
    Ok I get it don’t publish the license file.  I thought you could look at it and see what’s wrong.
    i just want to get on with the board I am designing!!
    https://www.element14.com/community/message/287100
    Thunderbird!
    Hi
    Your image error dialog says the "Installation Code " is (ten lower case
    letters)
    Maybe those uppercase letters are the problem
    HTH
    Warren
  • geralds
    0 geralds over 6 years ago in reply to tjnomad
    This letters in your image shown, are wrong.
    The correct letters are on the activation key disk or on your license certificate you received from Cadsoft.
  • tjnomad
    this the error:
