EAGLE User Support (English) how to assign a command
  • Subscribers 177 subscribers
  • Views 404 views
When I had used Protel and manualy route board, hen I press * key the layer
change from bottom to top and vice versa and automaticaly put via in place.
Now I wonder is it possible to achive this action in Eagle too?
    Options: Assign
    designate the keystroke you wish
    ex:  Ctrl-T for me clears all layers, shows the TOP layer, Tplace,
    torigins, tnames, pads, vias, unroutes, reference, holes, and dimension
    layers
    the command is shown below
    display NONE TOP Tplace torigins tnames pads vias unroute reference
    holes dimension
    essentially, you assign a command line type script to a specified
    keystroke.  This allows for a great deal of flexibility and power in
    Eagle.  Learn the command line instructions and you can do anything with
      "assign"
    plus, FYI
    search the forum prior to posting.  Repeat queries (such as this one)
    ruffle some feathers
    Ted75zcar
    autodeskguest over 17 years ago in reply to autodeskguest
    Hay,
    I had tried to work out this thing but I have no success. Can you give me
    some detailed instructions? Or full command...?
    HND
    "Ted75zcar" <tbrannan@sporian.com> wrote in message
    news:ft5sv4$i5c$1@cheetah.cadsoft.de...
    layer change from bottom to top and vice versa and automaticaly put via
    in place. Now I wonder is it possible to achive this action in Eagle too?
    Options: Assign
    layers
    display NONE TOP Tplace torigins tnames pads vias unroute reference holes
    dimension
    "assign"
    plus, FYI
    Ted75zcar
    "vinny" <vizer40@gmail.com> schrieb im Newsbeitrag
    news:ftkkeb$ac0$1@cheetah.cadsoft.de...
    Hay,
    HND
    - Described in the manual
    - HELP ASSIGN
    T.
    try the middle mouse button
    Lorenz
