EAGLE User Support (English) DRC Error Message with Text in Copper
  • Replies 7 replies
  • Subscribers 178 subscribers
  • Views 658 views
Hello!
Please see the attached file.
Using 4.16software version. A two layer board. Two lines of text are written
in the polygon labeled GND on each side, giving 4 error messages.
The rectangle around the LM1086 voltage regulator is a continuous wire, one
on each side of the board. The pour copper inside (and on each side of the
board) is acting as a heatsink.
As soon as I put text within this rectangle, I get the error message "DRC
Errors" related to the width.
What am I doing wrong. What parameter controls this.
Thank you for your help.
RJ
    Gentlemen,
    Thank you to both of you for your advice.
    RJ
    "T.Strothmann" <invalid.user@n-o-s-p-a-m.de> wrote in message
    news:ft7r25$rqe$1@cheetah.cadsoft.de...
    "John Giddy" <jgiddy@bigpond.net.au> schrieb im Newsbeitrag
    news:ft75qk$ord$1@cheetah.cadsoft.de...
    RJ wrote:
    Helllo John!
    You put me on the right track. Thank you. The minimum parameter are
    Size: .05 and Radio: 20% (see attachment).
    This is not looking nice thought. Is there a way to find out if it would
    come out good from the fab, despite the error message, with a smaller
    size and ratio? Is there a tool to verify / simulate the file gerb 274x
    (the format requested by my provider)?
    Thanks again for your help.
    RJ
    Well, you could always reduce the minimum width setting in DRC, but it
    would probably be best to talk to your board house to see what they
    recommend for minimum dimensions of features.
    John G.
    Texts do look already pretty bold at Size = 0.05" and Ratio = 20. At 0.05
    a ratio of >=12 looks much better. Since text is relatively uncritical, I
    always ignore this DRC error, never ran into any problems. Worst thing you
    can get is that if the track width is far too narrow the text may be
    etched away completely. Even if it's partially incomplete you can still
    read the text. It never went that far on my boards, though.
    This superfluous text line width DRC "error" is a long standing issue. May
    I suggest at this point that there should be another "minimum width"
    setting for tracks which do not belong to nets, such as those texts.
    T.
    Gentlemen,
    RJ
    RJ wrote:
    Helllo John!
    RJ
    John G.
    T.
