EAGLE User Support (English) Noob question on renaming library elements
  • Subscribers 177 subscribers
  • Views 299 views
  I have just started to use Eagle.   I want to make custom libraries with
parts from my BOM.  I have located a ULP called rename-in-lbr, but cannot
make it work.   What I am trying to do is duplicate a complete part and
rename it.  For example, I am trying to use the LT1366 dual op amp to make
an LT1490 - same footprint and symbol.   All that needs to change is the
name and description.  I find library management in Eagle to be a pain.
Maybe I am missing something.
       Bruce Griffing
    "Bruce Griffing" <bgriffing@hot.rr.com> schrieb im Newsbeitrag
    news:ft97qf$5if$1@cheetah.cadsoft.de...
          Bruce Griffing
    Sentence 2: try exp-project-lbr.ulp
    Sentence 4+: COPY the part in the schematics.
    Sentence 7: I agree.
    T.
           Bruce Griffing
    The library management can be a pain, but it is worthwhile working your way
    around it.  There are a few issues here.
    For a simple dual op amp just make a new device, selecting the symbol and
    package that already exist.  If you are doing this in your own lib rather
    than the origianl the part can be copied over very easily, by opening your
    lib, then going to the control panel, browsing the lib containing the part
    you want to copy and then selecting the appropriate part and right clicking,
    and selecting copy to lib.
    My second issue would be a matter for personal preference, but for generic
    footprint and pinpout opamps I always just use a general purpose dual op amp
    part and then give it the appropriate name.  This saves having a immense
    amount of different parts in your libs for components which are identical in
    all but name. A little bit like not having each individual resistor value
    with its own part.
    cheers
    David
