EAGLE User Support (English) I want to get a list ofwires and which nodes they attached to.
  • Subscribers 179 subscribers
  • Views 337 views
I may be doing point-to-point wiring (wire wrap) on my hobby clock project.
It would really help if I had a list of each wire, with the pin numbers on
each IC where it will be fastened. It's an ambitious project, as the clock
will handle different length months, daylight saving time and leap years
using about 30 74HCT series logic gates plus drivers for the Nixie tubes.
I've looked at the program LENGTH.ULP which seems to touch on many of the
details I would like, but I'm not familiar with the programming yet.
I can probably figure it out a ULP in a few weeks to a month, but if anyone
has already written something close it will save me a bunch of aggrivation
and debugging. In short, what I'd like is a listing something like: WIRE
hour_bit_1-- IC1 pin3, IC5 pin9, CON2 pin 16.
Thanks, Bill
    Thanks, Bill
    Have you looked at the export menu. netlist, pinlist ... should be what
    you need.
    When I did small prototypes I would layout a pcb and then use traces
    like I would use the wire wrap runs and then use that as guide to wiring.
    With that many connections considering the cost of wirewrap sockets you
    may be able to do it with a bare bones PCB.
    Off topic -- would be to use a micro or programmable logic in place of
    discrete logic.
    Paul R.
    Thanks, Paul. That looks like what I need. As far as wirewrap sockets, what
    I'm actually doing is soldering 30-gauge wire to conventional sockets on
    perfboard.. It gives a retro-wire-wrap look without actually using the
    proper sockets. And of course I could do a microprocessor, but that's not
    even close to the era of Nixie tube displays. I'm trying for a 1960s look on
    this project with all the circuitry visible though a lucite case.
    Sure, it's going to cost more, and be lots more complicated,  than a $10
    clock from Walmart. But that's's not my design goal and I'm having lots of
    fun creating it. (That's the whole reason we have hobbies.)
    --Bill
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:ftj3o2$7ao$1@cheetah.cadsoft.de...
    project. It would really help if I had a list of each wire, with the pin
    numbers on each IC where it will be fastened. It's an ambitious project,
    as the clock will handle different length months, daylight saving time
    and leap years using about 30 74HCT series logic gates plus drivers for
    the Nixie tubes. I've looked at the program LENGTH.ULP which seems to
    touch on many of the details I would like, but I'm not familiar with the
    programming yet.
    anyone has already written something close it will save me a bunch of
    aggrivation and debugging. In short, what I'd like is a listing something
    like: WIRE hour_bit_1-- IC1 pin3, IC5 pin9, CON2 pin 16.
    Thanks, Bill
    you need.
    When I did small prototypes I would layout a pcb and then use traces like
    discrete logic.
    Paul R.
    programming yet.
    Thanks, Bill
    you need.
    discrete logic.
    Paul R.
    sockets, what
    not
    look on
    lots of
    > --Bill
    Hey Bill - using 74HCT is cheating a little bit.  Depending on how far
    back in the 60's you go we could be taking about DTL or even RTL, and
    let's not forget the original 74xx logic.  Of course you'd need a much
    bigger power supply.  Even 74LS sucks lots of juice compared to 74CHT !
    -Dave
