EAGLE User Support (English) Eagle usage questions
  • Subscribers 177 subscribers
  • Views 182 views
My company just purchased Eagle and have the following questions.
Schematics
i) Is it able to select a group of components and then move or copy instead
moving one by one?
ii)Is it able to copy from one schematic and then paste into another
schematic? Just like we do in MS Words or Excel.
PCB layout
i) Miter function
    Is it possible to have all the joints on the trace miter instead of
doing one by one?
ii) Change trace width
    Is it possible to change width of the trace as a whole instead of every
segment?
iii) Is it possible to edit component on the worksheet instead from the
library. That is, I can modify a component and use only on the specific
layout and no need to build library for future use.
iv) During modification of traces path, I have first to delete the existing
traces segment by segment first and then route the new trace. Is it possible
that after I finish routing the new trace the old trace will be removed
automatically?
Power tools v4.15
I have tried non-registered version but the following questions
encountered.
    i) cannot import dxf schematic
    ii) some of the traces are missed when importing dxf PCB layout file.
    iii) During gerber import, only 1 layer at a time. Is it possible to
import all layers together?
Sorry for my naive questions cos I am really new to Eagle.
Thank you for your kind attention!
    "Murata" <cmc9897@hotmail.com> schrieb im Newsbeitrag
    news:fu1hq7$km4$1@cheetah.cadsoft.de...
    Is that the Murata like in www dot murata dot com ? Just curious.
    Schematics
    instead
    moving one by one?
    GROUP, then MOVE (right click).
    Try HELP GROUP, HELP MOVE.
    PCB layout
    i) Miter function
    doing one by one?
    You mean applying constant radii to all joints? No. Does not make much sense
    as long as there is no automatic push & shove. Can lead to numerous
    collisions otherwise.
    segment?
    GROUP, then CHANGE WIDTH (right click).
    Try HELP...
    No. I agree there's clearly too much messing around with component libraries
    in Eagle.
    existing
    possible
    automatically?
    You should be able to modify traces in nearly any way you want without
    deleting them:
    CHANGE WIDTH,
    MIRROR,
    SPLIT,
    and so on. Refer to the manual to learn more.
    Power tools v4.15
    encountered.
    Without having worked with Power Tools, I would guess that DXF does not
    contain the necessary information to allow a direct conversion to an Eagle
    schematics. This is a graphical format without support for netlists, for
    instance. DXFs can be imported, but only as plain graphical data.
    T.
