EAGLE User Support (English) invert silkscreen layer
  • Subscribers 177 subscribers
  • Views 354 views
Hello, is there a way to invert a silkscreen layer so that the copy is
negative space on a silkscreened background?
Basically, I have a graphic drawn in the silkscreen layer and I woulld like
to make highly visable by inverting the graphic so that it is a BLOCK of
silkscreened color. The graphic would be the negative space of which there
is much less, thus the high visibility.
THanx,
Tony
    I should add that I would like to do this inversion to only a portion of the
    silkscreen layer, in order to draw attention to the appropriate area.
    Thanx,
    Tony
    "Tony Rolando" <tony@moogmusic.com> wrote in message
    news:fua37n$lr5$1@cheetah.cadsoft.de...
    like to make highly visable by inverting the graphic so that it is a BLOCK
    of silkscreened color. The graphic would be the negative space of which
    there is much less, thus the high visibility.
    THanx,
    Tony
    THanx,
    Tony
    I  guess you are using the ULP to import the Logo. Why not use any old
    graphics program to make a negative of the logo, and then import that ?
    John G.
    I am not using the ULP to import the Logo. The graphic is drawn in Eagle. I
    suppose I could export the graphic, invert in another program, and the
    import using the ulp... I would prefer to do this within Eagle image
    Tony
    "John Giddy" <jgiddy@bigpond.net.au> wrote in message
    news:fua3dc$lrr$1@cheetah.cadsoft.de...
    BLOCK of silkscreened color. The graphic would be the negative space of
    which there is much less, thus the high visibility.
    THanx,
    Tony
    John G.
