EAGLE User Support (English) Pin Name with bar above
  • Subscribers 189 subscribers
  • Views 3114 views
In the library/symbol editor. I can assign a 'dot' to cause an inverter
(circle) to show; but how do I enter the pin name such that it has a bar
above the text? e.g.
___
xyz
Jake
  • esilviu
    esilviu over 18 years ago
    you can use "!name" because in version 5 this is the way "name" will have
    the top bar
    and version 5 is ready
    "Tilmann Reh" <tilmannreh@despammed.com> wrote in message
    news:fundbg$3eb$1@cheetah.cadsoft.de...
    David Pollum schrieb:
    Because many CAD packages don't support the bar, people have appended an
    "" or "#" to the end of the name.  For example, "xyz" indicates an
    active LOW signal.
    Many different nomenclatures are commonly used. Examples:
    /xyz  (preferred by me, PALASM syntax image )
    *xyz
    #xyz
    Nxyz
    xyz/
    xyz\
    xyz-
    xyz*
    xyz#
    Pick the one you are familiar with or which you can read most easily.
    Tilmann
    ___
    xyz
    Jake
    active LOW signal.
    -Dave Pollum
    active LOW signal.
    *xyz
    #xyz
    Nxyz
    xyz/
    xyz\
    xyz-
    xyz*
    xyz#
    Tilmann
    e14 Contributor over 18 years ago
    works only with V5 (coming soon)
    r
