EAGLE User Support (English) board not centered
  • Subscribers 179 subscribers
  • Views 406 views
board not centered
Former Member over 17 years ago
When I click the FIT button, my board does not zoom to fit but rather
reduces in size and is placed in the lower right corner.Also when I try
to print the board, it is printed much too small despite that I have a
scale factor of 1:1
  I can't figure out how to fix this.
    scale factor of 1:1
    Sounds like you might have something else on the screen that you are not
    seeing.  Try a Display All, and zoom into the opposite corner to check,
    or just select everything outside your title block using a group command
    and delete it.
    Former Member over 17 years ago in reply to autodeskguest
    Try: set used_layers all, enter
    r
  • esilviu
    esilviu over 17 years ago
    please ceck the orientation for names and values of the components at board
    limits.
    having a name oriented vertically and with origin down-side will make FIT
    function to keep some empty space over the end of the text.
    "Ken Arck" <ah6le@ah6le.net> wrote in message
    news:fuqefm$fcj$1@cheetah.cadsoft.de...
    reduces in size and is placed in the lower right corner.Also when I try to
    print the board, it is printed much too small despite that I have a scale
    factor of 1:1
