EAGLE User Support (English) Exporting design to Gerber files.
  • Subscribers 178 subscribers
  • Views 369 views
Hello!
I have made some small PCB in the free version of Eagle version 4,16r2.
It's two small boards i have made, and i have the same problem on both.
I'm using GcPrevue for viewing the gerber files i have exported.
Export in Eagle was done by running the excellon.job and gerb274x.job
Importing the files into GcPrevue gives me this errors:
Warning: Zero and/or negative dimension tools detected in the following
tool tables:
a001, "New Combined Aperture Table"
and after that:
User Alert:
3 files imported with critical errors.
Review import results for details.
The imported PCB looks fine, but my drill layer seems to be 10 times to
big in dimensions!
The imported file is here for anyone to look at:
http://www.zapro.dk/public/pcb/Koblerstyring.gwk
Anyone with any comments on this ?? - i'm going crazy to figure this out!
Per Jensen.
  • Richard_H
    Richard_H over 17 years ago
    Per Jensen schrieb:
    Hello!
    tool tables:
    and after that:
    User Alert:
    big in dimensions!
    I suppose that GCPrevue does not recognize the drill data format
    correctly. EAGLE exports drill data in 2.4 fomat, inch.
    Tried this file but it doesn't work at all with my GCPrevue....
    Richard Hammerl
    Update your GCPrevue. I'm using Ver. 16.2.2 and import of the file works.
    // Per.
    Per Jensen wrote:
    Hello!
    tool tables:
    and after that:
    User Alert:
    big in dimensions!
    Per Jensen.
    In the past, I've had drill locations not line up with pads, but I'm not
    entirely sure how I fixed it.  The only things that I can think of is to
    have the offsets set at 0 and to check the posCord box in gerb274x.cam.
        BTW, your solder mask isn't lined up either.  And it looks like your
    component-side copper layer "stikprint.cmp" has outlines of your
    connectors.  These outlines should only be in the silk-screen layer (*.PLC).
    If you can post your BRD file, I'll be happy to run the CAM job and see
    what I get.
    HTH
    -Dave Pollum
