EAGLE User Support (English) PDF crashes
  • Subscribers 178 subscribers
  • Views 320 views
PDF crashes
Generating a PDF using the built in feature produces a document which causes
certain Readers to crash, maybe because of malformed positioning
information. Suspicious file via PM to KLS.
T.
  • kcadsoft
    kcadsoft over 17 years ago
    I have tested your file with the Foxit reader (which is the one you mentioned
    in your PM) from
    http://downloads.foxitsoftware.com/foxitreader/FoxitReader23_setup.exe
    It loads your file just fine, and turning the mouse wheel scrolls
    up and down. No crash so far.
    You wrote "certain Readers" (plural) - can you name others that crash?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> schrieb im Newsbeitrag
    news:fvmupg$fv$1@cheetah.cadsoft.de...
    causes certain Readers to crash, maybe because of malformed positioning
    mentioned
    in your PM) from
    1. I assume something is different in these Eagle PDFs, when I found the
    problem I was able to open all other files I tried.
    2. The crash occurred with an earlier version of Foxit Reader. In a try to
    fix things I upgraded to the newest version which did not help at that time.
    I tried again today (because Foxit asked for this PDF), but to my surprise
    everything went fine. I assume because the PC rebooted in the meantime.
    3. Foxit received the file in question. I have asked them to notify me if
    they find anything unusual in the file. If so, I will come back to you.
    I remember I had problems with Acrobat which I got rid of in the meantime.
    The entire installation was ~200MB before I removed it. This thing became
    way too slow for my taste, and made some trouble when opening PDFs (went
    stuck quite frequently so I had to kill the task) -- but I'm very sorry,
    since I wiped Adobe off the system I cannot tell which Eagle generated files
    were affected.
    T.
    Klaus Schmidinger
