EAGLE User Support (English) eagle 5.0.0 - open with problem [Win Xp]
  • Subscribers 178 subscribers
  • Views 465 views
esilviu
esilviu over 17 years ago
as with an older beta version, windows can't correctly asociate .sch, .brd
or .lbr with eagle.exe.
"eagle" it's not listed in "Open with" list of applications, and it's not
added with "Browse" button.
Solved manually, with regedit:
Windows Registry Editor Version 5.00
@="\"C:
Program Files
Electro
EAGLE-5.0.0
bin
eagle.exe\" \"%1\""
after this, eagle is in "open with..." list
    @="\"C:
    Program Files
    Electro
    EAGLE-5.0.0
    bin
    eagle.exe\" \"%1\""
    Hi;
    messing around with the Win registry can be a bit of an adventure for
    experienced users and a disaster for the less familiar.
    Highlighting the file name and Right-Click or otherwise get to the open-with
    menu.  Enter the folder where eagle.exe is and be sure to Check the littlt
    box to always open the file type with Eagle.  Using the Win Open-With
    dialog is very safe and will always open the files with the selected .EXE
    When the dialog closes it makes the required reg entries.
    regards,
    Brownie
  • esilviu
    can't you read?!!!! - IT DOES NOT WORK THIS WAY!!!!
    "Brownie" <nomail00@worldpath.net> wrote in message
    news:fvatn6$6vn$1@cheetah.cadsoft.de...
    .brd
    @="\"C:
    Program Files
    Electro
    EAGLE-5.0.0
    bin
    eagle.exe\" \"%1\""
    Hi;
    open-with
    regards,
    Brownie
    Ease up there, no need to get so upset and start shouting about it
    I believe the browse option, when right clicking the file, does not work as
    there will already be an eagle entry in the open with window options, and
    windows won't like having a duplicate.
    However you still do not need to go delving into the registry and can indeed
    browse to the eagle v 5 program using a slightly different approach
    The alternative is to open windows explorer, select Tools- folder options-
    file types.
    Now find your entry for brd - open it click on advanced option- select open
    and edit, then you CAN BROWSE to the eagle v 5 directory and change the
    default open program.
    cheers
    David
  • esilviu
    "David Moodie" <dgmoodie@onetel.com.cut_this_off> wrote in message
    news:fvc14j$5nk$1@cheetah.cadsoft.de...
    file types.
    open and edit, then you CAN BROWSE to the eagle v 5 directory and change
    the default open program.
    tryied this ay too, and guess what?! :  it did'n work either.
    I can set-up the .sch to be opened with any other exe file, but not with
    eagle.exe. Windows seems not to accept eagle.exe in "open with" list.
    And all that I've changed in registry is
    @="\"C:
    Program Files
    Electro
    EAGLE-4.90
    bin
    eagle.exe\" \"%1\""
    with
    @="\"C:
    Program Files
    Electro
    EAGLE-5.0.0
    bin
    eagle.exe\" \"%1\""
    Eagle installer seems unable to update this key, and this key (wrong value)
    seems to block windows to assign ".sch"... to "eagle.exe"
    file types.
    Well there you go.
    Strangely enough I've always had Eagle as an "open with" option, after
    associating brd files with it manually by the above method I believe.. but
    it was a long time ago.
    In this case to test with v5 I only did the above with brd files and it
    works without any problem.  Were you also unable to achieve an association
    with brd files with this method or did you only try .sch files
    .sch files are a little trickier, due to windows existing built in
    association for this type... although "open with" eagle does pop up as an
    option for me, it is for eagle v 4.16. there is no problem for associating
    v4.16 eagle with .sch files.. but that's not the real issue
    I could get rid of v4.16 and try from scratch with v5, and would be fairly
    confident of it working on this set up, but as I have no current plans on
    moving to v5 I'm not about to go down that route.
    @="\"C:
    Program Files
    Electro
    EAGLE-4.90
    bin
    eagle.exe\" \"%1\""
    with
    @="\"C:
    Program Files
    Electro
    EAGLE-5.0.0
    bin
    eagle.exe\" \"%1\""
    That would be an issue to bring up with cadsoft. I'm not sure that they even
    try to modify the registry
      Still it's always good to have a couple of different options when wishing
    to do these things
    cheers
    David
