EAGLE User Support (English) suitable video card for EAGLE 4.09r2
  • Subscribers 177 subscribers
  • Views 282 views
hi,
recently i moved from my old win98 system to a new machine
that runs XP. On the old system i had an AGP card which
produced only minor problems at high magnification.
The new card (with more memory!) causes big trouble.
I have to restart EAGLE in the average every 30 minutes.
Thank God it allows me to save my work before i have to
restart the program.
Unfortunately i can not use the old video card in the
new system because there is no AGP slot.
Can somebody recommend a modern (fastPCI) video card that
supports two 19inch monitors (1280X1024) even at maximum
magnification for EAGLE4.09r2 with an XP system.
With maximum magnification i mean a 0.00625 grid becoming
clearly visible. The board is a little larger than A4.
  thanks a lot
   Horst Hartmann
    horst schrieb:
    While I can't recommend any particular grafics card, I would suggest to
    first try the latest 4.0x version. The latest beta version 4.09r56 fixed
    several bugs occuring at some particular system configurations. Don't
    worry about the beta status, it was the most stable 4.0x at all.
    Unfortunately, it is not available on CadSofts FTP server any more (at
    least I didn't find it within seconds...). You could send me a mail to
    the reply-to address (or ask CadSoft for that version).
    Maybe your problems vanish with that version.
    And, BTW, always use the latest drivers for your card. Did you already
    check that?
    Tilmann
    horst schreef:
    hi,
    thanks a lot
      Horst Hartmann
    what exactly is the 'big trouble'? After installing Eagle on your new
    computer did you check the "always use vector font" option? This is
    known to cause graphic problems. maybe it has nothing to do with your
    new videocard.
    Just guessing,
    Richard Herman
