EAGLE User Support (English) Embedded / Buried padstacks
  • Subscribers 178 subscribers
  • Views 94 views
Does anyone have experience how to create embedded / buried pins with Eagle?
Description of embedded pin:
Instead of having padstack information on surface layers, padstack should be
located inside of the PWB stack-up e.g. in case of 6 layer board into layer
4.
Br: Tero
  • Richard_H
    Richard_H over 17 years ago
    Tero Kärkkäinen schrieb:
    Eagle?
    should be located inside of the PWB stack-up e.g. in case of 6 layer
    board into layer 4.
    Br: Tero
    First is to define a proper Layer Setup in the Design Rules' Layer tab.
    Then you can use the VIA command and use Vias with the appropriate
    length (4-6).
    HTH
    Richard Hammerl
