EAGLE User Support (English) net signal name inconsistency error report despite consistent layout & schematic
  • Subscribers 178 subscribers
  • Views 559 views
Hello
I am new to Eagle and I am using EAGLE Version 4.15 Copyright (c) 1988-2005
CadSoft
I am getting 3 errors/warnings about net name inconsistency in-between the
schematic and layout (pcb). Except for  one of the errors/warnings, I do not
see anything wrong when I use show "net name" in both schematic and PCB.
Here is an excerpt of what I get with erc.
Pins/Pads with different connections:
  Part                        Gate     Pin        Net
Pad      Signal
  SV1                       G$1      13         BYPASS_ON           13
S$5
  VCO_CHOKE         G$1      P$2        VDD                        P$2
  X_VCO_SUPPLY    G$1      1          DC_PROBE_OUT      1
ERROR: Board and schematic are not consistent!
    1 errors
   21 warnings
1. First of all it seems like I have 3 errors but the erc report says there
is only 1 error. Which one of the three is really an error?
2. Upon investigation of the first warning/error, in the PCB I am seeing the
net/signal S$5 as a dot on the pin of SV1 device (MA13-2- "PIN HEADER")
device. However in the PCB I have this pin connected correctly to the signal
"BYPASS_ON" just like the schematic. I just can't get rid of this "S$5". I
tried ripup but S$5 stays. I moved the device to see if any net (in the form
of a dot) stays behind but none does. It is almost like somehow S$5 is
embedded onto this pin #13. By the way there is no net S$5 in the schematic
anywhere.
Any advice?
3. As far as the last two warnings/errors are concerned. I feel I have
correctly connected the pins of these devices in the PCB layout and given
the nets correct name using name command. My interpretation of the last two
warnings are that in the layout the pins of the parts are not connected to
any signal. I do not understand why these two warnings are appearing. Any
suggestions?
I would really appreciate if anyone could give an insight into any of the
above issues. Thanks in advance.
Pankaj Kataria
  • Richard_H
    Richard_H over 17 years ago
    Pankaj Kataria schrieb:
    Hello
    CadSoft
      Part                        Gate     Pin        Net
    Pad      Signal
    S$5
        1 errors
       21 warnings
    ERC first checks the schematic for plausibility and additionlly
    compares schematic and board, if existing.
    All messages are classified as a warning or an error. Read the messges
    and decide what to do.
    The messages concerning consistency are at the end of the ERC file.
    In your case all those about different connections in sch/brd.
    anywhere.
    Any advice?
    Try to set a VIA with name S$5 near the pad. RATSNEST should calculate
    an airwire now. Can you delete S$5 now?
    suggestions?
    The pad in the layout are not connected to any signal. So you have to
    draw an airwire (SIGNAL command) and name it the same as it is in
    the schematic. Aferwards start ERC. Schematic and board should be
    consistent again.
    How comes difference? Maybe you accidentally closed the board file
    and connected the pins in the schematic....
    Richard Hammerl
  • Richard_H
    Hello
    CadSoft
      Part                        Gate     Pin        Net
    Pad      Signal
    S$5
        1 errors
       21 warnings
    anywhere.
    Any advice?
    suggestions?
    consistent again.
    Richard Hammerl
