EAGLE User Support (English) 5.0 on MAC  OS 10.3.9
  • Subscribers 179 subscribers
  • Views 324 views
Hello, I wanted to test drive the new 5.0 version of Eagle, but I noticed
that it requires Mac OS 10.4 or newer. Has anybody run Eagle 5 on Mac OS
10.3.9? Is it operating ok?
THank you,
Tony
  • Richard_H
    Richard_H over 17 years ago
    THank you,
    Tony
    Tried it with a 10.3.3 installation and did not succeed in starting
    EAGLE. Currently I don't know the exact reason why it does not work.
    I think it must be at least 10.4.
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    I finally got the time to try Eagle 5 in Mac OS 10.3.9
    It seems to work fine. I opened several projects and moved stuff around did
    some re-routing etc... Of course I was working from copies and I did not
    bother saving any of my work in 5.0.
    I have not taken a project from start to finish, still a little nervous
    about that...
    I would like to hear from anybody using Eagle OS 10.3.9
    I do not want to pay for the OS 10.4 upgrade if I do not need it!
    Tony
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g0eb81$utn$1@cheetah.cadsoft.de...
    THank you,
    Tony
    Richard Hammerl
    In article <g3ofj1$vg6$1@cheetah.cadsoft.de>,
    about that...
    Tony
    THank you,
    Tony
    Richard Hammerl
    If the OS X client for Eagle-5 uses C++, and is built using GCC4 under
    Xcode, the resulting binary will require the dynamic lib for libstdc++
    to be present at runtime.  That lib wasn't added until 10.3.9 (it is
    provided as part of the OS).
    This is a little different from past versions of dev tools on OS X where
    you could have the C++ runtime embedded statically in the app.
    This may or may not be the issue at hand here but I thought it was worth
    mentioning.
    Rob
    "Rob Barris" <rbarris@mac.com> wrote in message
    news:rbarris-30EC92.21481923062008@news.cadsoft.de...
    did
    about that...
    Tony
    noticed
    OS
    THank you,
    Tony
    Richard Hammerl
    mentioning.
    Rob
    Rob, that would explain why Richard was NOT able to run Eagle 5 on Mac OS
    10.3.3
    Thanx for the insight.
    Tony
