EAGLE User Support (English) automatic path eagle freeware key for puppy linux
  • Subscribers 178 subscribers
  • Views 494 views
I installed eagle 4.16 on my puppy-linux using the pb_debianinstaller.
Everything works fine except I always have to tell Eagle that the
freeware key is at the difficult to remember location:
/usr/lib/eagle/bin/freeware.key
It would be easier if I could start eagle right with this path filled
out. I mean somethig like:
eagle --use_path_to_key /usr/lib/eagle/bin/freeware.key
Is there a possibility to achieve this?
regards,
hugo
  • kcadsoft
    kcadsoft over 17 years ago
    regards,
    hugo
    As nobody answers my question, maybe I should explain a bit better why I
    ask this question. Puppy-linux is a superfast linux distribution which
    installs on almost every medium. As I want to have my favorite
    CAD-software always with me I installed eagle 4.16 on it. When I
    remaster the distribution with remasterpup2 I need to know which files I
    have to put extra below /tmp/root or it would also be sufficient to be
    able to start eagle with the path mentioned above, but how?
    Just remove the eagle.key file from EAGLE's 'bin' directory.
    The next time you start EAGLE it will ask whether to use the
    freeware license key (which is also in the 'bin' directory).
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    autodeskguest over 17 years ago in reply to kcadsoft
    pb_debianinstaller. Everything works fine except I always have to
    tell Eagle that the freeware key is at the difficult to remember
    regards,
    hugo
    I ask this question. Puppy-linux is a superfast linux distribution
    which installs on almost every medium. As I want to have my favorite
    I have to put extra below /tmp/root or it would also be sufficient to
    be able to start eagle with the path mentioned above, but how?
    Klaus Schmidinger
    thanks,
    I will try this out
    regards,
    hugo
    Klaus Schmidinger
    thanks,
    I will try this out
