EAGLE User Support (English) Gerber for componets on both sides
  • Subscribers 178 subscribers
  • Views 224 views
I've done a design with components on the two sides (not smd components),
and I have to generate the gerber files for it. How I have to modify
gerber.cam to describe it? Do I have to generate two *.cmp files, one for
the top sided components and the second one for the bottom sided components?
And the same question with the other files generated with gerber.cam (*.sol,
*.plc, ...)
Thank you in advance.
Best regards.
  • Richard_H
    Richard_H over 17 years ago
    Julio Pérez schrieb:
    *.plc, ...)
    Best regards.
    What you normally need:
    File name   Selected layers      Description
    .cmp        1 17 18              Component side (top)
    .sol        16 17 18             Solder side (bottom)
    .plc        21 25 (20)           Silk screen component side
    .pls        22 26 (20)           Silk screen solder side
    .stc        30                   Solder stop component side
    .sts        31                   Solder stop solder side
    .crc        32                   Cream frame component side
    .crs        33                   Cream frame solder side
    For drill data (EXCELLON)
    .drl        44 45               All drillings
    Richard Hammerl
