EAGLE User Support (English) Import pre-made .brd
  • Subscribers 187 subscribers
  • Views 1577 views
subhumanaudio
subhumanaudio over 5 years ago
Greetings,  just learning Eagle and I think it is great and somewhat easy to understand. How can I use a pre-made brd file to use with my schematic? A friend designed a brd for me to use as I design some audio gear and need to use his board size and layout for it to work. Can’t ask my friend anymore as he had passed away awhile back.
any help would be much appreciated.
thank you.
  • WarrenBrayshaw
    0 WarrenBrayshaw over 5 years ago
    If you would care to attach your Sch and Brd files someone may be able to suggest the most efficient approach.
    Cheers
    Warren
    0 dougw over 5 years ago
    Basically, you need to make the schematic match the board exactly. Components, names and connections.
    Eagle will tell you what doesn't match between the schematic and the board, but you will have to manually edit the schematic so that those things that don't match are swapped or changed to be equivalent to the corresponding things on the board. With the same names and the same connections. It isn't hard to do, but it is a bit tedious and you have to be very meticulous.
