EAGLE User Support (English) Ground pour disappears after save
  • Views 478 views
I'm new to eagle 4.16...
Designed a simple two-layer relay board, with a ground wire pad connected to
two relay contacts by a bottom-layer ground pour, for greater
current-carrying capacity.
On the schematic, the net is called GND and connected to a GND supply pin.
No ERC errors.
On the board, first I route all the other traces. I have a few short
airwires left between the wire pad, and the relay contacts.
I draw a polygon and name it GND, and hit Ratsnest, and a lovely ground pour
appears. If I use the Info button, it says it is GND.
Problem: I save the board, and when I re-open it, the ground pour is gone,
and I just see the polygon! If I Retsnest again, the ground pour
reappears... until I save it again.
I must be doing something wrong, but I can't figure it out. Can anyone help?
thanks
--eric g
    e14 Contributor over 18 years ago
    Help Ratsnest
    r
    That's perfectly correct. Only the polygon is saved in the *.brd file. Never
    the filled area.
    "Eric Griswold" <eric@clevian.com> wrote in message
    news:g1h8vl$la8$1@cheetah.cadsoft.de...
    to
    No ERC errors.
    pour
    help?
    thanks
    --eric g
