EAGLE User Support (English) panelize question
  • Subscribers 178 subscribers
  • Views 263 views
panelize question
I have designed a small two layer PCB and I am at a stage where I want
to print the PCB onto a sheet of tracing paper.
In order to save time and resources, I would like to print three PCB's
onto the same sheet. I also want to print the solder side and the
(mirrored) component side onto the same sheet. How can I do this?
I have cut the finished PCB layout from the brd file and pasted 6
instances of it into another brd file. Now I need to display the solder
side for 3 of them and the component side for the other 3. I also need
to mirror the component side. As easy as it sounds, I still haven't
figured out how to do this. It seems displaying layers cannot be limited
to a selection. It affects the whole layout.
Any insight is greatly appreciated...
Timur Aydin
    Timur Aydin wrote:
    The standard procedure for home printing is pretty straightforward.  But you
    are making things difficult by trying to print top and bottom at the same
    time.  My advice would be to forget this and do them separately which makes
    it a simple process. If you are really concerned about using 2 sheets
    instead of 1 then cut the paper in half before printing, and ensure that the
    vertical position for the print out is set as Top in the page set up dialogue.
    Make a fresh copy of the complete board and save under a new name
    close the schematic.  This is one of the few times you actually do this but
    you'll have found this out already.
    Turn on all layers group and copy as appropriate.
    For printing you simply select the appropriate layers from the layer menu
    and print.
    Top side 1 17 18 20
    bottom 16 17 18 20  (select mirror option in print dialogue)
    For optimum results change options set misc display mode to no drills. This
    gives you solid pads in the print out
    Run drill-aid ulp which provides a new layer 116 with small holes for all
    pads. Turn on layer 116 when printing the bottom layer.  This makes the
    printout have solid pads with only a small hole on the bottom to help when
    manually drilling.
    cheers
    David
    Timur Aydin wrote:
    and print.
    Top side 1 17 18 20
    manually drilling.
    cheers
    David
