EAGLE User Support (English) Board milling
  • Views 232 views
Board milling
we have a special board with 400um kcopperthickness. The PCB producers
can not produce the board with convetional methods
We have a milling router in our company, and board layout is not complex
(no thin tracks, only big vias and large ground und supply plane.
PCB is doubleside:  2.4mm boardthickness withpout copper, 400um copper
thickness on both sides.
My question: Can I produce a GCODE for TOP(1) , bottom (2) und milling
layer (46) and then produce it by the router .
If not, is there a 3th party utulity for that.
Best Regards.
FI
  • esilviu
    esilviu over 18 years ago
    yes, it is possible
    you can try "gcode.ulp" from download area of cadsoft
    Or you could try gcode from attached archive. Unzip-it to ULP dir of Eagle,
    and run gcode.ulp
    I used dimension layer for board contour and other cut's.
    If you have questions, post-them here or on my mail
    "FI" <ferhat@incal.com.tr> wrote in message
    news:g1ue8u$nct$1@cheetah.cadsoft.de...
    Best Regards.
    FI
    gcode.zip
