EAGLE User Support (English) Counter Bore Drill
  • Subscribers 177 subscribers
  • Views 194 views
Counter Bore Drill
Using 4.x version, I'd like to put a .030 counter bore hole in a .062 board
for a wire turret. Very tight small board, don't have room on the board to
go all the way thru. I believe the manufacturer supports this (checking on
that) But I don't see any way to specify drill depth in Eagle. Any
suggestions?
Bruce
    suggestions?
    Bruce
    How many layers has your board got?
    Although many manufacturers support blind and buried vias, this is done on
    multilayer boards, where it is then relatively straight forward and
    achieving it in eagle is dependent upon your drc settings.
    Alternatively for a two layer board it would be a special milling operation,
    which most certainly would be non standard.
    What you need to do is
    1. Phone the manufacturers before hand find out what they require and can do.
    2. write detailed instructions in your readme file
    3. send the files to your manufacturer
    4. phone them up again and speak to the person taking care of your job.
    cheers
    David
