I can trestrict, and brestrict for the top and bottom, but I also need to
restrict an inner layer. I'm trying to restrict the area for an antenna. I
also have an inner ground layer that I need to restrict.
There are no "restrict" layers for the inner layers. You have to use
polygons (eventually more than one) that have the correct outlines.
You might also draw a wire of another signal name around the area that
shall not be flooded. Of course this wire will be present in the board
later. (But take care if something else, like a via, carries the
polygon's signal in there...)
I also have an inner ground layer that I need to restrict.
"Supply layers" can not be restricted by definition. You have to change
it to a normal routing layer and then use ground polygon(s).
(Remove your reply-to-address if it's the same as the from-address.)
Tilmann
Tilmann
