EAGLE User Support (English) How to document Vscoring on a board
  • Subscribers 177 subscribers
  • Views 160 views
I am designing a board that requires Vscoring to allow parts of the
board to be snapped off after assembly.  The board house needs a fab
drawing for this Vscoring, and I will generate this drawing directly
from my Eagle layout (using the CAM processor).  Is there a convention
for the layer on which elements are placed to be put into a fab drawing?
Steve
    Generally, the board houses just need some information where to score. I
    don't think there is a "convention", but the board houses widely accept
    gerber files for whatever information (like milling, scoring etc.).
    For scored boards, I always add a custom layer "vscore" and draw very
    thin lines (0.01mm) there. Then I simply provide a gerber file of that
    layer along with the other gerber files. It has alwas worked perfectly.
    Just take care to tell them that you want scoring and in which file the
    data is - otherwise it might be ignored...
    Tilmann
