EAGLE User Support (English) Pin Names
  • Subscribers 178 subscribers
  • Views 258 views
Pin Names
The distance between the pin and associated name in the symbol editor
appears to be fixed and equal to 0.1" which is a rather big gap.
I looked in the "Edit" and "Options" menu items but couldn't find a way to
change this. Is it somehow possible to change this gap size?
Second question : vertical pins in a symbol have their name also oriented
vertically. Is there a way to chage this to horizontal? If I have one GND at
the botttom and one Vcc pin at the top of a symbol, I'd prefer to have the
names "GND" and "VCC" horizontally because in that way they don't interfere
with the names of the horizontal pins, unless I make the symbol a lot bigger
than really necessary.
I should add that I'm still using version 4.11 and that these remarks might
be no longer valid on more recent versions.
    You can't change any of these default positions and orientation for the pin
    name.
    What you can do is hide the pin name and type in a new name as a text field
    positioning it wherever you wish.
    Upgrade to v4.16 which is still covered by v4.11 license.  No major changes
    but some minor fixes as I recall.
    cheers
    David
    name.
    cheers
    David
