EAGLE User Support (English) OT: Glue a Component to PCB
  • Replies 7 replies
  • Subscribers 187 subscribers
  • Views 957 views
Hello, I need to reinforce a large component on a PCB to avoid stressing the
solder joints. What have you all used to do this?
Epoxy, all purpose glue, RTV etc... ???
Thanx,
Tony
    autodeskguest over 18 years ago in reply to autodeskguest
    What about a clear silicon?  Even a small tube like is used to seal fish
    tanks.  It will hold the part in place, but can be removed if need.
    I've seen this used on many boards.
    James Morrison wrote:
    On 2008/Jun/12 6:28 PM, in article g2s7tl$dcp$1@cheetah.cadsoft.de, "LGR"
    <lgr@nventure.com> wrote:
    You didn't say it had to be pretty.
    Truth is, unless you know exactly what the board is made from, and exactly
    what the part you're gluing is made out of, ugly is a possibility. Epoxy,
    being a copolymer, is probably less likely than other real glues to attack
    parts.
    You also didn't mention how much support you need. RTV might work, but it
    won't provide much support without the part moving. If you just need
    compressive strength, hot melt is commonly used. I've seen hot melt used all
    the time in consumer electronics to secure all manner of things.
    Another possibility (again, it depends on exactly what you're trying to do)
    is to put pairs of holes in strategic locations and then use a tie wrap to
    go through them and around the component.  I've used this technique for a
    large cap that sits parallel to the PCB to keep it fixed to the board.
    Worked very well.  And easy to rework in a way that epoxy/glue isn't
    sometimes.
    The hot melt glue gun is a good one in some instances as well.
    As for epoxy eating through your PCB, there are epoxies specifically created
    for just this application.  Those are safe.  But yes, any random epoxy/glue
    on any particular PCB material could cause chemical issues.  But that isn't
    really new news.
    Cheers,
    James.
    Thanx for all the advice guys. I really like the tie wrap method as I have
    definitely spent time peeling away at RTV to get at a part. Also suggested
    by an engineer around here was gasket cement.
    Cheers,
    Tony
    "David Moodie" <dgmoodie@onetel.com.cut_this_off> wrote in message
    news:g2tf2s$edu$1@cheetah.cadsoft.de...
    Tony Rolando wrote:
    Well, I just talked to one of the engineers and he is saying that there
    is the possibility that epoxy will eat through the soldermask. Not so
    good looking I suppose. On the upside, most of the Epoxy i looked at had
    very high dielectric ratings.
    Tony
    There are several adhesives designed specifically for this purpose.
    Two I use are Loctite tak pak 382, good for wires and small items
    and Loctite Black Tak 4105 for larger items
    Neither are particularly cheap , but they do the job.
    cheers
    David
    Tony Rolando wrote:
    Well, I just talked to one of the engineers and he is saying that there is
    the possibility that epoxy will eat through the soldermask. Not so good
    looking I suppose. On the upside, most of the Epoxy i looked at had very
    Tony
    cheers
    David
    parts.
    sometimes.
    really new news.
    Cheers,
    James.
    ~  James Morrison                          ~
    ~  email:  james@eagletoolkit.com          ~
    ~  fax:    888.701.8097                    ~
    ~  web:    http://www.eagletoolkit.com     ~
    ~  Online EAGLE Dealer for US and Canada   ~
    ~  EAGLE Design Experts                    ~
    ~  EAGLE Enterprise Toolkit                ~
    parts.
    "Tony Rolando" <tony@moogmusic.com> wrote in message
    news:g2ruha$ial$1@cheetah.cadsoft.de...
    Tony
    "LGR" <lgr@nventure.com> wrote in message
    news:g2rtfi$f3i$1@cheetah.cadsoft.de...
    I've used super glue just fine. You don't have a lot of time to get it
    positioned right, though. Epoxy is probably better. You know you have
    about 5 minutes from when you mix it.
    news:g2roab$9c$1@cheetah.cadsoft.de...
    the solder joints. What have you all used to do this?
    Thanx,
    Tony
    Tony
    Thanx,
    Tony
    positioned right, though. Epoxy is probably better. You know you have about
    Thanx,
    Tony
